The net trailer capacity weight is 8200 and the 24's max running weight is 6800#s so I have room to spare there. I measured the height of the brackets and they vary from low in the back to higher in the front by 2.5". I'm guessing that is normal on all cat trailers as it is that way on both of these trailers. Until I get the 24 off the trailer I'm also guessing that the plane from front to back is a straight line and not concave or convex. My plan is to cut the bolts off the brackets as they are welded, slid them over to the right center lines, raise them enough to clear the fenders and rebolt them down. Lower and widen the center guide and rebolt it. I'm going to have to take a look at the weight distribution one of you have mentioned. I'm hoping with the world cat being longer and heavier than the 24 that it will all be relative and not matter, but I will check it out.
