- Joined
- Sep 30, 2006
- Messages
- 4,671
- Reaction score
- 1
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Vessel Name
- 'Au Kai (Ocean Traveler)
Titan Model #10 surge actuator.
-How long should it last?
-What kind of force is needed to activate the emergency break away lever?
Reason I'm asking is I was out doing basic maintenance on the trailer (grease hubs, check brake fluid, grease things up etc) and the master cylinder and actuator look pretty rusty after our wet winter. I tried to pull the actuator lever by hand; no luck. So I used the truck to pull it, to make sure it's working. It did not activate but straightened out the "S" hook instead. :shock: This tells me something is amiss. Removed the lever, looked down inside and everything looks OK but it's a rusty mess.
Time for a new one? The trailer is a 2007 King Saltwater.
http://titan-intl.com/files/Trailer_Components/IIs/model10ii.pdf
