spuncopper
- Joined
- Sep 2, 2012
- Messages
- 194
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 16 Cruiser
- Vessel Name
- Sock Monkey
Hey Guys n Gals:
I have a Suzuke 50DF on my 16 Cruiser. Recently I had an alarm go off and discovered that I had a restricted water flow from my tattle tell. The lower unit had just been serviced with a new impeller installed.
I discovered that there is what appears to be a breather tube just above the water outlet (the tattle tell). An inspection revealed what appeared to be insect larva plugging this breather tube.
After cleaning this out everything was fine until the next time we put the boat in. Once again I found what appreared to be insect larva plugging this breather tube. We cleaned it out again and now use a simple fix.
I put painter's masking tape over this breather tube when I put the boat up after a weekend's use. It has worked great. I would suggest using a color that is easy to spot, we use blue.
A friend of ours had to have a small Honda completely torn down to clean dirt dabbers out of his engine after it had been sitting for a summer.
Be safe folks! Sam
Be safe folks! Sam
