Pete in NY
- Joined
- Jul 11, 2004
- Messages
- 131
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- CD025072E404
- Vessel Name
- Miss Pam
I have seen this misconception before in this thread. Wood mouting blocks can be fastened to the inside of uneven glass surfaces with Bostik urethanes or 3M 5200 or 4200. The tricky part is holding the piece in place while the urethane cures. Duct tape works. So does celophane packing tape about 2 inches wide. The job is done in two stages. First you put the adhesive on the block but keep it away from the edges. Set the block on the fiberglass and tape in place. After it has cured, a bead can be caulked up around the edges to make a neat joint that fills the gaps. After curing this is strong. When I was looking for a boat before buying my CD25 I went to Maine and visited a number of builders of Downeast glass hulls. Some had fiberglass houses and hulls and teak interiors. Guess what? The interiors except for glassed in structural bulkheads are glued in with Bostick. The urethane has some advantage also since it makes up for the different rates of thermal expansion between the wood and the fiberglass.starcrafttom":2lr22rsk said:With glass you will have to thru bolt the fiberglass and have the bolts showing on the out side of the cabinet.
That being said, I did not like the molded interior of the Cape Cruiser and love the look and solid feel of my Decraguard interior with teak trim.
