mgarr682
- Joined
- Sep 29, 2012
- Messages
- 182
- Reaction score
- 0
- C Dory Year
- 2013
- C Dory Model
- 22 Angler
- Hull Identification Number
- CMC22002J213
- Vessel Name
- Glenda Jean
I need to find a wire from my ignition that will supply power for the fuel flow meter when the engine switch is turned on and cut power when the switch is turned off. Does anyone happen to have any Honda documentation for the switch/shift/throttle and instrument wiring that comes with the current Honda 90?
There is a bundle of wires from the shift/throttle mechanism that comes out behind the dash to feed the three installed gauges (tach/hour meter, trim meter, volt meter) and has additional bundles of wires marked fuel, speedometer, and water. The red wire from the bundle marked water is connected to the nav lights switch and supplies power to the instrument lights. I'm not sure how that works but it does.
I think the gauges are actually Teleflex although they are marked Honda on the face. Looking at the Teleflex website they look the same otherwise, particularly as far as the electrical connections on the back.
The tach/hour meter has a wire to the "IGN" terminal that according to the Teleflex website is a 12 volt feed from the engine switch. Checking it with a volt meter showed it to be hot (meter showed 12 volts, but it was a six dollar meter twenty years ago) when the switch is on and dead when the switch is off, which is what I need for the fuel flow meter.
The fuel flow meter requires a 12 volt switched power source and is to be fused at 1 amp so I'm thinking power requirements should be minimal. My question is, do you think the "IGN" wire would be an adequate source or should I be searching for another switched source?
Any suggestions or opinions welcome!
