Suzuki 90 clearances
The Commodore
I'm installing a jack plate for my Honda kicker. How much space do I need to allow between the main engine (a Suzuki 90)? the current adjustable motor mount for the kicker needs to go. The new jack plate will, I think, need to mounted a bit closer to the centerline of the boat. Where do I find this info? thanks
Tape measure and transom?
That should do it??
Turn your main motor as far as it will go to the side your going to mount the kicker. Turn the kicker towards the main and adjust it so they don't hit each other. Also check them when they are tilled.
