Rubrail repair
This is a long post, but I figure anyone about to do the job might like to read about and see the details. Otherwise feel free to just scroll past the text and look at the photos
When I first looked at my 22 (before purchasing it), there was already one spot in which the rub rail was coming loose - the few inches on the port-side transom just after the 90º turn. I had read about the problem/fixes here, so put it on my to-do list. It wasn't high up on the list, however, as the fasteners only went into the self-draining port lazarette. But then as I was waxing the boat while it was in storage this winter… I saw that the rail had come loose amidships on both sides. You could see "air" between the rail and the boat, and the rivets had broken. This meant I had holes (or soon to be holes) in each side of the boat amidships. Time to fix!
(Note, these are the slightly smaller versions of each image so no-one has to scroll back and forth. The larger version can be seen in my album, after clicking twice on the thumbnail)
It's a little hard to see in the photo, but where the arrow is pointing you can see air (gravel shows through from ground below). It was much more noticeable in person.
I re-read any threads I could find on the repair, to glean tips and ideas. Comfy Dory did an extensive write up, along with photos in the Comfy Dory album. This along with the accounts of others gave me a good idea what I was up against (thank you to those earlier posters :thup). Of course first I had to bemoan the whole idea: Build a boat, 'glass the hull and deck together (many boats are only bolted/screwed and not glassed) so you have a perfectly watertight vessel…. and then drill 100+ holes just to attach a rubrail, and fasten it with wimpy aluminum rivets :cry Better yet, have a design that catches and holds water…. :amgry Now granted, they were likely to want to put something there - it does cover up the unfinished looking seam between hull and deck - and it is certainly nice to have a rubrail.
I used to have a small fiberglass trailer that had a similar construction (although even worse as they used steel plates inside to anchor the rivets, which rusted and bulged), and some people removed it and went back with a modern heavy rubber automotive (such as on a light truck) "belly band" type molding that attaches with VHB tape. That might not hold up (not sure), would not stand as proud (disadvantage) and you'd have to do some smoothing of the hull-deck joint. So I nixed that idea. Then I thought of a big/heavy rubber profile that I have seen on some boats, wherein there is no metal. The rubber "gives" such that when you tighten it it basically makes a seal against the boat (and there may not be a channel to hold water against the fasteners). Also the fasteners may not be buried/covered such that they rest in the soup. I didn't look too heavily into that at this time though, because I decided not to completely pull the rails off since only a small section on each one had failed.
Backing up a little, to begin the repair/thought process, I removed the rubber molding that covers the fasteners (rivets) on our rails. What I found was that 90% of them were in good shape, but seven of them on each side (more or less amidships) were deteriorated or broken. This is where "low point" water can sit.
If you look closely at the tip of the arrow in the above photo, you can see the broken end of the rivet tube. That would have been at the outside of the rail, attached to the rivet head - so you can see how the rail has pulled away after the rivet head broke. Where the rail bulges it makes it look like there is "too much rail" (and indeed I found where several others had mentioned this and said they were even thinking of cutting out a small section of "extra"), but I found that when it is sucked back in with new fasteners it fits perfectly, at least on my boat.
The rest of them looked pristine (although I expect that eventually they might fail).
Since I had other things on my project list, and I didn't have extensive helper availability where I am now (but I did have some, yay), I decided to repair just the rivets that had failed or were about to fail. My reasoning went like this:
1) The current problem will be fixed, literally better than new.
2) If/when future rivets fail, I may choose not to remove the complete rail, but instead to leave the middle section I just repaired, and "wing out" the forward and aft sections on both sides, so that I'm essentially doing the rest of it in four sections. I found out by doing this section that while it would be nice to remove the whole rail for some reasons, I can do it in place. And with the "wings" it would only be one or two rivets (close to the now-repaired section) that would have limited access - the rest of the rail should pull out plenty far. A side benefit would be not having huge "loose" rails to deal with.
3) Or, if I do want to remove the whole thing, and/or replace it with something different, I can always undo the fasteners I just used for the repair and take the whole rail off then.
So next I set to removing the broken rivets. First to explain (likely obvious) that where the rivets terminate on the inside is a "blob" of slightly rubbery material that covers the rivet. This was said to be 5200 in many posts. This is then gelcoated over when the whole inside of the hull is done (sprayed type, not molded). So there is the issue of how to handle that. About half of the to-be-replaced rivet's heads had fallen off and were lying in the rail gutter. The ones that were still on were mostly easy to drill off, except for a few where the mandrel was still in them (little rod blocking hole) - those were a pain. I wondered if that was steel and hence the corrosion was hastened? Once I had all the heads off, it was time to drive the body/back of the rivet into the boat and remove it. I saw where Comfy Dory had found that if he simply drove them in, they pulled off a ragged bunch of "the blob," which was a cosmetic problem. So he used a piece of thinwall pipe and from the inside, cut a circle in the blob around the rivet, so that when he drove the rivet in, only a neat circle of blob was removed. I did the same thing, utilizing a punch/cutter that you use to cut a circle of fabric before installing a grommet (#2 I think). I just rotated it back and forth (clockwise and anti-clockwise) and cut the blob that way. This worked very well.
I then used a nail set in the tube on the outside, and hammered the rivet into the boat. Here is a removed tube, with circular section of "blob" on inboard end:
This photo shows a row of the holes after the rivets/tubes were removed:
I thought about the original problem, and debated cutting a few weep holes/slots in the bottom of the rail. For now I decided not to, as I figured it might just clog anyway. I can always go back and do it later if I change my mind. My next decision was fastener type and material. I was loathe to use stainless, since this would set up a mixed metal situation, and worse, the metal would likely be sitting in a "soup." So I thought about using aluminum machine screws, so no mixed metals. I really wasn't sure if they would be strong enough or not. I mean, it's only a rubrail, but it does take a fair bit of tension/force to hold it to the side of the boat.
So I tried aluminum fasteners in a dry fit experiment on the "worst" offender (most tension to hold together), which was the little piece on the transom just after the 90º bend. What ended up happening was the threads on the machine screw stripped. Now, this may have been my fault, as I used a plain stainless nut. Reason was I wanted to feel how it was going (for the experiment) and I only had Nylocks in aluminum, which don't provide much feel. I reasoned that an aluminum nut might not have caused this, because it would have had "just as much motivation" to keep on tightening as it would to strip, whereas maybe the stainless, being stronger, could be "lazy" and just start cutting into the threads on the aluminum fastener vs. keeping on tightening. My buddy who was helping me thought that made no difference, and either one would have stripped the screw. At any rate, I decided to skip the aluminum and go stainless. The last thing I wanted was a bunch of stripped fasteners. If I had been doing the whole rail I might have done more experimentation and not given up so easily on the aluminum.
Next I had to figure out head style. 98% of the holes in the rubrail are tapered (to fit a tapered head screw), although one or two added holes (where they needed an additional fastener) are just plain. Still, a couple of them were slightly enlarged (where the broken rivets had allowed some movement), and…. I just wanted a bit more bearing area. On the other hand, I didn't want so much "stuff" protruding (washer, panhead screw head) that it would get in the way of the rubber insert. Ultimately, I decided to use Truss headed screws, which have a wider flat head (no taper in the shank) and can be used without washers -- for plenty of bearing area but no excess height. On the inside, although I usually like to use washer/lockwasher/nut, I decided to go with Nylock type nuts for the least protrusion. It looked as though 1" fasteners would leave the screw just, juuuuust coming out the end of the Nylock (this turned out to be right, and 1" was perfect). I also thought about acorn nuts for looks (with lockwashers) but that would protrude further into the cabin. And I even bought some locking acorn nuts, but when they arrived they were some unusual alloy of stainless (forget which, but not 304 or 316) and were really ugly looking (dull, pitted, etc.) so I ruled those out. I also got some "thin" Nylocks in case that might be needed. And some 1-1/4" screws just in case. 1" and 3/4" fender washers for the inside. I bought all of the fasteners/washers/nuts in 316 alloy stainless since it is less corrosion-prone than 304. Size #10 fit perfectly (see materials list below). Another factor is that most of these aren't going to show. All the ones on the starboard side are either under the galley or behind the shift selector; the ones in the port lazarette are out of sight, and the ones on port side, while they do show slightly, are mostly out of sight under the side deck or behind the forward seat cushion. If I were doing long swaths of obvious ones (v-berth), I might have chosen the acorn nuts even if they protruded more.
To try to isolate the mixed metals as much as possible I took a few measures.
1) I got some extremely thin isolating washers from McMaster-Carr to use on the outside under the truss heads. They are sort of the feel/thickness of mylar.
2) I coated the fasteners with Tef-Gel (should also keep nut from galling).
3) I was liberal with the caulk
4) I think I may go back and put some Te-Gel on the outside of the fastener heads (in the rail behind the rubber) but not sure on that yet. Stainless does like to have oxygen contact.
Next to decide on sealant. I really like butyl and usually use it anywhere I can. I would have used it here except that since I was only doing a short section of rail on each side, I really had no way to get it in behind the rail to lay in butyl tape. The "gunnable" butyl has a lot of mineral spirits in it and I don't like it as well as the putty/tape style. And I wanted a gunnable caulk. For me that left it between polysulfide and polyether. I've had such bad luck lately in getting polysulfide that wasn't half gone off already in the tube, that I decided to use polyether. The one regret I have on this is that I have never (yet) had to remove it, so I don't know how hard that might be (butyl and polysulfide both clean up like a dream when you have to remove them). I might have tried harder to get good polysulfide if I were doing the whole rail (or used butyl). In this case I decided to use 3M4000 in a caulk tube, so gunnable.
The last thing I had some misgivings about was putting the new washers/nuts right over the "blobs" on the inside of the boat, but I somewhat reluctantly decided to try it, since others had, and it certainly would be easier cosmetically. However…. I was not at all happy with the way that worked in reality, at least on my boat. First of all, the blobs were fairly flexible. I was concerned that as they slowly compressed over time, the fasteners would loosen (or they would stay the same due to the Nylocks but the now "thinner" hull would allow the rail to loosen and to move around). Second, the hull behind the blobs is not flat (it is in the hull-deck joint area) but is concave in varying degrees, and so the washers were turning into "Pringles" as they were tightened. I just wasn't happy with it. I remember reading in one of the Pardeys' early books that when Larry Pardey was a young boatbuilder, an old sage builder once told him, "Larry, if there is any part or method you are having second thoughts about as you are putting it into the boat, just pull it out then and do it right; you'll be glad later." He did and was. So I decided not to continue with "the blobs." Of course I had to resist the temptation to just keep on going and "get 'er done," but in the end I'm glad I didn't keep going that way.
Instead, next I held the 1" washers up on the inside of the hull, centered on the hole, and traced around them with a pencil. Then I used an X-acto knife to cut a circle from the blob, and then chiseled the blob away inside the circle down to bare fiberglass. This went pretty easily and I had them all done in a an hour or so. Once I had a few of these removed "blob circles" to experiment on, I used various solvents on them. Reason is the blobs just did not feel like 5200 (polyurethane) to me. And they were such neat little blobs, and 5200 is not that easy to make perfect like that. Lastly, they seemed a bit too soft for ten-year-old 5200. Well given that mineral spirits was able to dissolve them, plus their texture, plus evidence where it was used in other places on the boat (water fill, a through hull), I think it was polysulfide. I was not at all sorry about this, as it meant it would be easy to remove/clean up wherever I wanted to (and it was). So I cut all of the subject blobs away in 1" diameter circles, sanded then cleaned up the fiberglass beneath, taped off, and then applied thickened epoxy slightly generously. When that got to the early green stage (still somewhat pliable), I wrapped a 1" washer in clear packaging tape, with a "tail" to grip on one side, and then pressed it into the green epoxy such as to flatten it perpendicular to the hull. Because of the remaining blob and the overall shape of the hull there, there was no easy way to do it the usual way (with a big straight edge like concrete). Then I let it get a bit firmer and chiseled away any excess, only leaving the 1" circle of flatness/epoxy. I also epoxy filled (and then re-drilled) a couple of the holes that were a bit sloppy in the hull.
I still had some cosmetics to think about. If I do this more extensively later (i.e. more of the rail comes loose), I will do it when I have a month or more, chisel off all of the blobs entirely, epoxy the area to make it flat, let the epoxy cure for a good long while, and then paint over the entire area (before putting the fasteners on). In this case I didn't have enough time to really let the epoxy cure (paint/gelcoat doesn't dry well on recently cured epoxy), and the fasteners were mostly in unseen areas. Still, I did chisel off one entire blob just as an experiment. What I will do this time is let the epoxy continue to cure for some time, and then after Powell I will go back and "hand paint" around the washers. For 14 holes this will not be bad, but for an entire rubrail it would be nicer to do it the other way, and let the epoxy cure, then paint (or gelcoat) nice circles around the whole area before the fasteners go on.
So (once again!) I got everything cleaned up (never figured out if alcohol affects polyether the way it does polyurethane, so to be on the safe side I cleaned/prepped with acetone), taped/masked off five ways from Sunday, cleaned and Tef-Geled the fasteners, got my helper, and away we went. Compared to all the prep and decisions, the actual job went easily/quickly (isn't that always the way), and I felt really good about having the firm/flat surface to put the washers on, vs. the resilient blobs and/or undulating hull.
The procedure went as follows:
1) Have everything masked off and prepped, all tools set out, many little squares of paper towel just in case, solvent to hand, trash bag, disposable gloves on.
2) Helper (outside boat) has container of pre-Tef-Gelled and pre-polyamide washered fasteners, plus screwdriver.
3) Inside the boat, I have the washers, nuts, spanner, and socket/driver, more gloves, towels, and trash bag.
4) I put thumb over hole, while helper guns caulk into outside hole. We somewhat go by feel as to how much sealant to put in. I want a generous amount under the rail and in the hole, but not too much. I want zero sealant outside the rail (ultimately). When we judge it is just right, helper pushes fastener through hole and holds it still (not allowing it to turn) from outside. I clean off the caulk on the end of the fastener, put on washers and nut (1" washer, 3/4" washer, standard locknut), and tighten it down most of the way. We then move and do all seven in a row on one side, then I go back and tighten them further in a staggered pattern, making them fully tight (I don't subscribe to the tighten part way, let it cure, then go back method). The screw itself is held from moving by helper on the outside, so as to disturb the caulk as little as possible. I clean up the (very minimal) overflow inside the boat, then go outside and clean that up, and then we move on to the other side. Here is how they looked after fully tightening and cleaning off excess caulk, plus removing tape and masking (I don't like "beads" of caulk on the outside of things, so did not leave any caulk above or below the rail.)
Showing the rail tucked back in to the hull - this was the worst offender in the "separated from boat" category:
And here are some views of the inside. This first is the lazarette. I had to trim a couple of the washers where they had two holes close together securing the end cap. There were never "blobs" in this area. (The larger washer below is the inside of the handrail for the swim platform.) I think I might have used one of the thin Nylocks here, but I may have been able to go back with a normal one after the initial tightening, I forget. Otherwise they all took normal Nylocks and fit just right.
Under galley, where they will never show:
Behind dinette (you can see where I experimentally removed the entire blob around one of the fasteners). I will go back and paint carefully around the washers to improve the cosmetics.
Boy-oh-boy, does it feel good to have this (almost) done! No more having 17 holes in the boat! I am now just letting it cure for a few days, then I will reinstall the rubber strip. I think I'm going to go along and put a little dab of butyl putty on/in the open end of each of the remaining rivets. I don't like the idea that water can get into the tube and just sit there against the blob on the inside of the boat (plus helping to corrode the rivet tube), and since the boat has been indoors since last October (mostly in the dry SW), and wasn't in salt previously, this seems like a good time to do that. It will be easily removed if/when the time comes. I will also go back later, after the epoxy has had longer to cure, and hand paint around the washers on the inside to make them look better, cosmetically. I have some Pettit Easypoxy in "off white" that perfectly matches the "white" gelcoat of the C-Dory (thanks to Carpy for the recommendation). I may or may not first remove the remaining "blobs" (around the new washers, as I did on the one) - still thinking on that. If/when more of the rail comes loose, I'll either just continue as I have, or possible remove it and install the whole thing afresh; I'll figure that out if/when the time comes.
Here is a list of some of the materials used:
Fasteners, from McMaster-Carr, including part numbers:
94792A626 = Type 316 Ss Truss Head Phillips Machine Screw, 10-32 Thread, 1" Length (also had 1-1/4" on hand; did not use).
91435A190 = High-temp Insulating Polyimide Flat Washer, No. 10 Screw Size, .63" Od, .004"-.006" Thick
91525A114 = Type 316 Ss Large-diameter Flat Washer, No. 10 Screw Size, 1" Od, .033"-.047" Thick
91525A115 = Type 316 Ss Large-diameter Flat Washer, No. 10 Screw Size, 3/4" Od, .033"-.047" Thick
90715A115 = Type 316 Ss Nylon-insert Hex Locknut, 10-32 Thread Size, 3/8" Width, 15/64" Height
90101A225 = 18-8 Ss Nylon-insert Thin Hex Locknut, 10-32 Thread Size, 3/8" Width, 11/64" Height (had on hand, might have used one in lazarette)
Also used:
Tef-Gel isolating paste
3M-4000 caulk in gunnable tube
acetone/denatured alcohol/gloves/plastic/blue tape/tools, etc.
My rubrail insert is in great shape, but I did find that you can still buy it new. Jamestown Distributors had the best price for the length needed, but I also found it at other chandleries. It is Taco brand, part number V12-0303 (of course check your boat in case it is not the same).
