Well, I almost did myself in last night. Went down to the boat after dinner, it's on a lift, and started to fill/flush the fresh water tank. I had the lift motors going to lower it into the water so I could run the engines. In leaning over (that side of the boat is a stretch from the pier), I lost my balance and fell in! No one else there (my second or third mistake) and the generator was running (no juice on the pier yet). It was about 30 inches to the pier from the water surface, too high to hoist myself out.
What to do, lift is still coming down. Swam around the other side, I could reach the mud bottom but just barely. There is a ladder there but it was out of it's mounting and up on the pier. I managed to get it down and climb out. Stopped the lift/generator but not before most of the wire spooled off and tangled a bit. I worked with it a while but didn't have much success. Tied the boat off as it is now floating over the sunken lift. Came up to the house, showered and called the guy that installed it. Had to leave a number.
He called back this morning and will be over in a day or two to get it squared away.
Mistakes:
1. Going down alone. It's only about 500 feet from the house.
2. Running the lift while I did something else.
3. Reaching/leaning too far.
I think I've learned a lesson but at 65+, you'd think I knew better before. Apparently not!
Glad to be alive, no major damage (I don't think. We'll see about the lift wires). Bruises this morning but no other effects except to my ego
Mistakes:
