matt_unique
As a matter or prudence I always take a look into my rear bilge ports to see if there is water in the sponsons. Today with my engines running I looked into the port door and heard a strange noise.
I localized it to my port fuel tank when the engine is running. It initially sounded like arcing electricity. Obviously if that were happening in the fuel tank it would have already blown up. I looked in every port sponson orifice available on the Tomcat, front and back, and could see around the tank. There were no flashing lights, no smells, nothing like that. The more I thought about it....it could also be the sound of a partially plugged fuel line intake. The sound is loudest if I open the port fuel tank cap and lay my ear on it. The sound was intermittent but definitely when the engine was running.
Now...I also noticed a somewhat similar sound on the engine itself when I first turn the key on. I was thinking this may support my idea about a partially plugged fuel intake because I'm assuming my engines essentially draw in fuel via a fuel pump when you turn the key. The sound could be that of some air or something....not sure so I welcome any suggestions on the noise.
I ran both engines today from idle to 4000 rpm with no problems, no hesitation on the port engine, etc. I'm very low on fuel but certainly not empty.
Thanks for the ideas.
