Agreed. Harvey's method works fine if the slip is longer than the boat but is not so good if the slip is shorter. Also to be clear, I think Rob's using the "midship" cleat and not the bow cleat (which people might confuse when the terminology "forward cleat" is used). The midship cleat is great as it's far enough back from the bow to be on the wide part of the hull and hence forward motion with tension applied there will not pivot the bow in. If one uses a cleat closer to the bow, forward motion and tension there will pull the bow in. Jay - I'm sure you know this and meant the midship cleat (the one near the opening side windows on a 22) but I just wanted to make sure the method was clear to others. Aslo, with regard to bow the bow and the midship lines, I like mine to be as long as possible without being long enough to catch in the prop. That way if for some reason they get overboard, they are not a major issue.Hunkydory":vi1bofoo said:Harvey, I have tried the way you describe, with & without a loop at the end of the line to slip over the dock cleat. The problem we found is if the line is long enough to easily go over the dock cleat it allows the boat to go forward to far & without a loop, attaching to the cleat can take more time than the wind allows. That combined in the case of where we like to dock at Yellowstone Bridge Bay, with the strong afternoon winds pushing the bow into the electrical box mounted directly in between the two boat slips or another boat in the same two boat slip makes docking on the down wind side impossible for us especially with our large Manson Boss anchor. Rob's method of coming off the forward cleat using a measured line with a loop on the end could make docking where we prefer there possible under the normal afternoon southeast windy conditions. Docking on the other side of these two boat slips is easy with the wind holding the boat where it's wanted, but then if someone else has the other side veritably they will be hitting our boat in the process of their trying to dock.
In response to brooks&judy's post about not letting others on the dock handle your dock lines - another minor point about docking is making sure that your passengers are well trained about what to do and not to do prior to arriving at the dock - especially those who have boated before and they tend to want to be "helpful". I've had people jump off with just the stern line in hand and ruin perfectly good landing (the stern is the only end of the boat I really can control from the helm at slow speed) and I've had people make huge unsafe leaps to the when if they had waited a minute or two, I'd have the boat much closer. This is especially a concern when I've misjudged and am about to back out for a second shot at it.
When things are calm, I'd far prefer to just have new people on the boat stay out of my way. I'll bring the boat alongside the dock, and get out calmly with both the bow and stern lines in my hands. However, when there is a strong cross wind blowing me off the dock, I have to count on someone in the cockpit to help out. This past season at Ilwaco, I had to land to port in my assigned slip with a ~30kt wind trying to blow me off (and into a beautiful Ranger Tug in the slip to my starboard side). There were a couple of occasions where it took more than one attempt and on one of those occasions I had to shout to my helper to let go of the bow line while I backed out for the re-do. That was even after briefing the crew on what to do but not covering what to do if we didn't get on the dock in the first try. The situation wasn't helped at all by having a slip about 26' long and having a boat that's about 28' overall but at Ilwaco, I had to take what I could get.
