Yosef
1988 22 Cruiser "Heron" Eastern Washington (state)
My cable-based steering is easy and smooth as silk from lock to lock with the engine at idle but when I spin up the motor it gets stiffer and stiffer with speed.
I don't think it's the trim tab as it's approximately as difficult to turn the wheel either way.
There's a bit of a "breaking free" effect when initially turning the wheel but even then it's hard to turn after it's broke free.
The boat has a King Marine AutoPilot AP2000 and the steering is so stiff that the AP can't turn the wheel when the engine is spinning above 2,000 RPM.
The outboard is a 2004 Suzuki 90HP with the third zerk on the steering/tilt tube so the steering cable end is very well lubed.
The engine has a permatrim installed and, per:
https://www.permatrims.com/category_s/12.htm
the engine is 1.5" lower than permatrim recommends. I'm not sure if this would cause the stiffness?
-Joe Dowd
-Joe Dowd
