My Honda BF50 motor has been gradually idling worse and worse and now it started to hesitate between 1,300 rpm to 2,200 rpm.
If you have a similar problem here's what I did to clean up that mess:
1) Took out the pilot screws and clean them and reinstalled them (1 full turn after seating. Different for other motor models)
2) Replaced the spark plugs. Changed from Champion to NGK (probably not that important)
3) Replaced water/fuel filter
4) Removed the air baffle and ran Deep Creep to decarbonize till the cows came home.
5) Changed motor oil
6) Ran high concentration of sea foam in the fuel for 2 hours.
It purrrs now and have not run this quiet before.
I'm guessing that it's mainly # 1, 4 & 6. Hope it helps someone.
