Solitary sleep habits
Not For Hire
May 20, 2004
347
2004
Not For Hire
Okay got your attention? A note from Sea Wolf (Joe) in another discussion prompts me to ask a question I have been thinking about.
I am frequently single handing (with my 50 lb dog). I find that during the day I store gear on the port side to balance the boat. Clothes and some gear I keep in waterproof duffles in the cuddy. Also a heavy chair, boarding ladder, etc. At night my tendency is to move stuff from the port side in general and cuddy in particular to the starboard stern and then I sleep in the cuddy on the port side. I don't really know why except it seems there is more room there without the electronics panel.
So the question - where are you most comfortable sleeping when single handing? Port, starboard or dinette?
Do you find yourself shifting weight around prior to turning in?
Getting anxious to be afloat again in Michigan.
Regards,
We actually sleep across thwart with our heads to the port side; same if I am single handing. Gives me lots of room to store stuff in the cuddy even when we are sleeping and its easier to get in and out of.
Mark-
Just to explain a bit- 2 reasons I sleep on the dinette:
I have pinched nerves in my back and it's a lot easier to get into the dinnette bed instead of the v-berth.
I let my Great Dane use the v-berth to rest in underway and sleep in at night (I keep it extra padded and blanketed to keep it as clean as possible.
I always make up the dinette table to sleep on. I'm 5'7" and find it very comfortable. I often wake up several times at night and I like to have a quick look around if I wake up. Especially at anchor I am always nervous about dragging and I can raise up, take a quick look around, and drift off again. Beats crawling out of the cuddy.
I read your post this morning and decided it needed some testing on my part. So I loaded my first mate 'Daisy Mae" and we took the boat out into Naples Bay and dropped the hook. We tossed a line into the water and proceeded to head for the V-Birth. I tried out the Port Side first, then the Starboard....then I found myself Port to Starboard....and about 3 hours later I woke up with my nose pressed aginst the Port side and my feet to Starboard. Daisy was snuggled aginst my belly.
So to summarize: Sleeping aboard the C-Dory appears to be a work in progress and anyone sleeping with you had better be as accommodating as a 6lb. Papillon or your in trouble.
More testing will be performed in the coming months and all results will be reported here.
As a PS....total catch of the day...One SeaCat...was on that line when I awaken from testing.
