Sea Angel here;
The concern with the bow and breast lines coming loose and getting in the props are very real. The bow line is 25' and will not make it that far aft. The breast and stern lines are another issue. This line, also being 25', could make it to the twin props. The tight coil I try to use and the set of the 'bungeee' loop will have to be refined for a more secure hold. A stopper line could be also applied, but that may be too cumbersome unless you are in sever WX and want to be sure you have a secure WX deck.
The total bungee cord length I chose was 14". This will give me some latitude to do some twisting , or tightening, of the holding loop which is not shown in my pixs.
These cam cleats are the same ones shown above with the red caps, but a substitute cap cover can be added and obtained direct from HARKEN. The cam cleats were purchased for abt $29 each from WM along with the hangers for $5.79/pr; cordage is extra.
I chose this approach from my old sailing days use. These lines can be set and released very fast with positive assurance as long as the lines are properly sized to the cams. I did not see any need to color code the cams to their use, as I would on a sloop; but only to follow the colors of the boat. I don't think these are original ideas or applications.
I hope this adds to safer line handling. It will keep the decks clearer for safety and keep the lines from rubbing against the hull finish as much as it was.
Enough of my :roll: 2 cents worth. A belated Happy Easter to all.
