Gratitude
- Joined
- May 14, 2004
- Messages
- 90
- Reaction score
- 0
- C Dory Year
- 1992
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR22616E292
- Vessel Name
- C Pelican
While having our boat's annual service, we recently had a new heavy duty Garelick EEz-In Aluminum Auxiliary Motor Bracket installed on our 22' C-Dory. Unfortunately, while offshore my fishing buddies indicated that there was water accumulating in the rear cockpit. Upon investigation I did find about 1/2 inch of water sloshing around throughout the cockpit. I turned on both bilge pumps, and the water was evacuated in about 30 seconds. Unfortunately, this became the norm for the balance of the day. At first, I thought it was a loose drain plug, so we reached overboard, and tightened it. No affect. Upon return to port I bought a replacement drain plug, and installed it. Yesterday we took the boat out for a harbor cruise to test. Unfortunately, the issue continued. When I returned to the hoist service to put our boat back on it's trailer we inspected the transom where the auxiliary motor mount was installed. To my dismay we found one unplugged ~ 1/8" hole that went all the way through the transom below the waterline from the prior smaller motor mount that the dealer replaced with the new Garelick. The landing suggested pounding in a dowel, and sealing with 5200. Easy enough. However, my concern is moisture that could be trapped in the transom and potential for dry rot. I realize that I likely have recourse to the dealer that botched the installation. However, before I contact the dealer, I seek the group's advice. Is this a significant issue that requires more than a dowel and 5200?
As always, thank you for your thoughts and guidance.
All the Best,
Jim (Gratitude)
All the Best,
Jim (Gratitude)
