Securing the Overhead Shelf
Dreamer
Jan 1, 2006
1,766
If you have added a console for radios, etc. under the factory installed shelf, you may want to see how secure it is. I noticed a flex in rough water and inspected the mounting. On a TC-255, the shelf is held in place with the 2 bolts that secure the roof rails. I noticed that the next 2 roof rail bolts were about 2" aft of the shelf. Here's the fix I came up with. It's now rock solid.
I started with 2 stainless straps similar the this and a flat headed bolt usually used on toilets!
With the flat plate secured by the roof rail bolt, the flat head bolt head is pinned to the ceiling and protrudes through the shelf. A washer and acorn nut secure the shelf.
You will have to loosen the whole shelf while installing these. Don't try this alone while your wife is at a meeting. Don't ask me how I know this part!
Roger,
That looks like a good fix. I am trying to remember if my 22 has 4 screws through the shelf. Seems like it does, but not sure. It certainly does feel solid.
Steve
My only question would be how long was it before she came home?
Where there's a will, there's a way! Project was done by the time she came home.. I don't recommend those sorts of contortions however.
Had you still been in a bind waiting for her to return, it would at least been comforting to know that when she couldn't find you in the house, she'd come out to the boat to look for you, since that is where a good deal of our time is spent.
Whenever loosening the handrail screws that also hold the electronics shelf up, I use my adjustable length boat hook pole underneath the shelf to bolster it up so that with the screws removed I won't have to play Atlas to all the electronics on the shelf above.
Could ya' please hand me that little *#@%^?!+* screw I just dropped and that screwdriver over yonder on the helm seat?
Joe. :teeth :thup
Another good idea from Joe. Throughout my Brat years I have learned that Joe is full of it. Uh, information I mean.
Do you have pictures of your overhead screws? I have a feeling with my added shelf enclosure I will need to add a couple of screws to secure the shelf in bumpy seas.
Perfect...no drilling required!
Roger - where did you find that metal tab? What is it?
Thanks!
Matt,
They're from the sailboat hardware section of Fisheries Supply. Some sort of "tang" thingy! :| The sailors can tell us the proper name. I'm sure any chandelery would have them.
Good luck and Happy New Year :cocktail :cocktail
Picked up my 4" SS tangs today. I hope to put them on tomorrow. Our 1-2" snow forecast turned out to be 8"...
By the way, I just realized this thread is in the "Trailers and Towing" section. It would be great if an Admin could move it into the Cabin Interior section for future reference.
Thanks!
I am planning something similar, and have a question if you don't mind:
In hindsight, knowing what you know now, might it have been an option to build a new shelf/top that was that extended a few more inches aft so that the tangs weren't required?
Thanks...
mike
Interestingly I had the exact same thought, but mine was more of an interest since I own a 25' Cruiser and I had thought the upper shelves were identical on the 255 and the 25; but, obviously they're not (at least of particular model years). My 25 has four screws (x2/side) holding the shelf. I was surprised to see how the 255 accomodated securing of the shelf - interesting.
Wannaboat,
Good point! If I had prior knowledge of the flexing of the shelf under load, I probably would have built a whole new assenbly (shelf and radio console) and attached them to the 4 bolts.
So now you know. Be sure to post photos of your new shelf!
:wink: Roger
It's funny this came up....I thought about modifying the shelf such that it came out farther to cover up all my wires but it might be in the way.
Take a look at this picture:
http://www.c-brats.com/modules.php?set_ ... _photo.php
The teak fiddle to the right is the edge of the existing shelf before I installed the enclosure. If I extended the shelf out to cover these wires for example it would be in the way. (I will have to double check the next time I'm aboard but I'm pretty sure I figured out I could not change the overhead shelf without interfering with head room).
We ended up with so much snow (14 inches this weekend) I spent time shoveling and clearing off the roof instead of fun projects :\
Headroom is a function of how far one's head is from the deck. :)
Matt, how tall are you?
On another note, my TomCat also did not come with a radar arch. I am thinking about installing one because I want to stow a raft up there. But a radar mount would be less expensive and simpler to install.
Is there enough room up there for a raft behind your raydome?
Thanks...
mike
I'm 6'....I will get back aboard this week to install the tangs and double check the clearance. I swear me head just touched the shelf if I walked far enough forward such that I would not want to extend it any farther back.
I can fit my inflatable dingy perfectly between my all around light and the radar mount. I've got a Mercury 200 Roll Up (6'7" long).
For another idea on the overhead shelf. I'm 6' 4" and didn't want to reduce the headroom with an under shelf mount. I put a face on the overhead shelf and used it as the location for many options.
Brent
