My first post as an official C-Brat!
My wife and I recently purchased a 23' Venture. When we winterized her we noticed that the fresh water tank had what appears to be mold or algal contamination. I believe it's due to outside seawater and/or rain streaming into the freshwater tank from the thru-hull overfill/air tube.
My questionn is, how do I prevent this problem?
Ideally I'd like to install some sort of device that will allow water out of the line but completely prevent water from coming in. Even if such a thing existed, it might cause vacuum suction problems when I turn on the water pump because it would then be a sealed system not allowing air in.
I'm considering just plugging the hole through the hull and not having any sort of overfill tube, leaving the top opening open to still allow air in. It's a 20 gal tank and I'd like to get in the habit of only filling it with 10 gal so that at the end of a weekend I can empty the rest and always fill with fresh water before starting a trip. If I happen to really screw up and overfill there is a bilge pump right near the base of the water tank.
For now I've removed the tank and I'm going to clean it by filling it with 10% bleach solution.
Any information or suggestions on how to prevent this problem would be greatly appreciated!
Chris
Fish Hawk
Chris
Fish Hawk
