Roy and Lucky
Joe ~
Thank you for your reply; your input is always valuable.
I've never noticed water leaking on the inside of the cabin. The inside fiberglass joint between the hull and the cabin appears to be intact, with no separation. Now that the panic has passed, and I'm somewhat rational :shock: , a better description of the problem would be a 1/4" wide gap on the outside of the seam between the hull and the cabin that appears to be only as thick as the gel coat. There appears to be no damage caused by water intrusion in this open seam. I guess my 2 questions are:
1. Do I need to be concerned about damage due to water intrusion (the boat is a 2000 with no apparent structural damage to date, and I don't have to worry about freezing temperatures where I live)?
2. If the open seam is just an aesthetic issue due to some slacker taking a long break on a Monday morning and just covering the open seam with the rubrail, what's the proper fix? Marine structural filler? Gel paste? Bubble gum? Or just reinstall the rubrail as is and take a long break?
I believe you answered these questions and again I always value your input.
Thank you very, very much.
Roy
Roy
