Molly Brown
Member
Hello all Brats:
Had a few of the rivets holding my rub rail on, break loose. I peeled back the rubber insert and drilled out the broken rivets. Seemed simple enough to locate some aluminum rivets and replace them. I expected they each had their own hole,that is until I looked behind the rub rail. There is a slot cut the full length of the hull into which the rivets are supposed to go into. The problem is finding rivets that mushroom large enough to grab the backside of the hull as this slot is rather wide. Needless to say, I've exhausted all potential rivet supplies locally and have yet to find any that will work. Looking for your input before I take it down to the local boat repair company and just let them fixe it.
