C Sniper":39a6dzub said:
anyone want to tell me why this is a bad idea??? I really like the look!
https://boatbuildproject.com/images/Rope-Rub-Rail.jpg
For starters that rope is hemp or jute--which is short natural fibers, and does not wear well. Today, if you want to use a rope rub rail, then synthetics should be used.
As Boris says, this will not hold up to heavy abrasion. Hemp rope shrinks when wet. Prior to synthetics manilla rope made from the fibers of the abacá plant (grows in equatorial areas, such as Philippines.
To put a rope rub rail on a fiberglass boat there are two ways. One is to make a wooden inwale, which covers the hull to deck joint. That has to be fabricated, and then but to fit the contour of the hull. Then either rivet or bolted, with caulking to the boat. Then the rope is epoxied into the groove in the inwale.
The other is to get an extrusion which is similar to the extrusion by Toco used on the C Dory, but specifically for a certain sized rope. That has to be fixed to the C Dory as the factory extrusion is, and then the rope tapped into the extrusion. I would probably use some Boat Life, Life Calk in the extrusion to be sure it adheres and stays in place. It is best to have tension on the rope as it is set in place.
The extrusions for rope are made in both aluminum and rubber. In many ways the rubber is better, but probably more difficult to install in a C Dory.
When we built our 38 foot cruising sailboat, initially I wanted a heavy black rub rail, perhaps with rope insert. (The commercial look.). After some experimentation, we ended up putting a laminated teak rub rail in. Then a ss strip on top to take any heavy abrasion...(Teak was cheaper in the 1970's) I gave up on the rope, as being too subject to failures.
