Rogerar--I don't know which C Dory you own, but I don't know of any which would be well served by having the interior structure "stuck down" with 5200. There are small gaps between the floor and the wood of the cabinets (older boats with wooden built up interiors). The hull will flex slightly, the wood will not. Even with bulkheads which are fully tabbed in, there is an allowance for this flexing, with a foam wedge or spreading out the tabbing over a large surface, and allowing room for the flexing. 5200 is not an adhesive--it is meant as a sealant. Some times it sticks very well, and occasionaly it does not. But it will not take load well in stretching, and is not intended for this purpose.
Yes, I have replaced the "L" brackets in the CD 25 with fiberglass tabs. I do feel that an any boat where the core is drilled into, you should either drill out and replace the screws--or do the tabs. I didn't address the tabs, because of the question about replacing the screws and plated/galvanized brackets.
There are very few places in the C Dory hulls where the brackets are used, where water will stand, with the boat in the water--or with the transom down on a trailer. On some boats, positioned so that water can get into the cabin, there could be some minor intrusion of water into the core around rusting screws.
duvalra The issue is not plated or galvanized screws--but drilling into the core. This has been done since the boats were first made, and to my knowledge there has been no failure of the hulls due to this practice. I feel that it can be done better--and if I was building the boats, I would tab the bulkheads into the hull. But that is quite labor intensive. What is unique about this site, is that we are all honest about the criticisms of the boats--The factory has taken many of our criticisms and improved the boats through the years. You and your wife are entitled to your opinions--but I would suggest looking at a 25 year old C Dory and compare it to any other 25 year old boat--and then draw a conclusion--You will find that the C dory will fair much better than any but perhaps some very high end custom boats. In fact, I would say that the C Dory is the best value for the $$ in a boat that size--and my owning two C Dories is testimony to my conviction.
Below is an illustration of the way I tabbed in all of the wooden structure of the CD 25 by filling the holes, then securing with 18 oz triaxial cloth and epoxy between the hull and the laminate covered plywood structure: This totally resolves any potential issues.
