jhwilson
- Joined
- Jan 18, 2007
- Messages
- 214
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDO22502F606
- Vessel Name
- Placid C
My bilge pump discharge hose has totally disintegrated. As you know it runs from the pump behind the port fuel tank to two discharge fittings on the port side of the hull. Is there any way to replace the hose without removing the fuel tank? Do those discharge fittings (stainless or chrome)remove from the exterior of the hull? If so, how is it done? I tried the search function without any luck.
I'll sure use a better quality hose when I replace the bad one.
Thanks much in advance.
Harper
Harper
