Marco Flamingo
Active member
I'm putting my electrical system back together and I'm not sure if the prior owner had things set up correctly. And I'm not sure how the fuse block works with the switch panel (both of which appear to be stock on the CD 16).
The switch panel doesn't seem to be still produced by Blue Seas. It has 6 switches (cabin lights, radio, depth sounder, etc.). It has reset breakers that aren't marked, but the present Blue Seas panels are all 15A breakers.
The separate fuse panel holds 6 blade fuses and has a negative bus bar. It was basically unused. I think the prior owner added a lighted compass and a cigarette style plug-in (that wasn't fused).
There were a couple of in-line "add-on" fuses of the AGC glass tube variety and some spares on board. For instance, the positive wire coming from the depth sounder switch had an inline fuse.
The setup seems a little clunky. What does a 15A breaker do for the depth sounder switch when a 3A inline fuse is still needed? And the nearly empty fuse block could have a 3A blade fuse in one of the slots, but how to integrate this (if needed).
I'm just trying to simplify, simplify. Maybe the 15A breaker for the depth sounder could be (or has been) replaced by a 3A breaker and the inline fuse wasn't needed? Maybe all 6 of the connections in the fuse panel were for use in adding aftermarket gadgets?
Mark
Mark
