BTDT
- Joined
- Jan 7, 2011
- Messages
- 322
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Hull Identification Number
- CDO25570K607
- Vessel Name
- C- Lark Wine Down
Karl":15te1ece said:I believe that's a myth...the same engine block in an outboard (think only Honda and Suzuki do that) will be far more heavily stressed than in a car, where you are typically running 1/2-2/3 of redline, compared to much higher in most outboards. In an outboard, that block is putting out close to maximum power for a high duty-cycle, compared to automotive use. One reason: road rolling resistance is far lower than pushing water all day.
I beg to differ, at least in my case. The redline on a Honda Accord is 7000 (13,000 rpm on their race version). I have never hit 7000 on my Honda 150 outboards nor will my prop let me. Normal usage is an extended warmup as I clear the no wake zone in my Marina, and then accelerate to 3500 RPM (50% of redline) for less than one minute to get on plane, and then back to 2900 to 3000 to cruise at 18 mph. There is no dust for the engine to inhale, below freezing temperatures are always avoided, and run time is always sufficient to warm up the engine and burn off the bad stuff (acids etc). I don't pull long grades or cross deserts in high summer heat, nor do I drive a short distance to work each morning. I guess time will tell but at 2500 hours if you equate that to a car I would think that's about 125,000 miles (50x2500), and my engines are running perfectly. I also understand law enforcement have seen In excess of 10000 hours on their Honda outboards.
:thup
