Ok I love this site and all the info I can get and use for my new boat. I have a few questions. I want to take off my radar arch so I can weld a rocket launcher rod holder to it.
1. I would like to take the Radome off and pull the wire to it out of the tube, so I will not melt the wire to my radar. Can I unhook the wire that goes into the Radome? I would rather try to unhook it from the radome side instead of trying to find the end of that cable that goes a couple miles inside of my boat.
2. I have the same problem with my raymarine gps antenna. Does it unhook at the end of the antenna, that is hooked to my radar arch?
3. I also need to replace my vhf radio antenna, ( tip broken off about 6 inchs) I unhooked the connection where the antenna wire goes into the radio. Seemed pretty basic except for the end connection. Does a new antenna come with a new connection? Do you just cut off the excess amount of cable? Does it require a special tool to crimp the new connection on? VHF antenna wire needs to come out so I do not burn it also.
I am trying to make this project as clean as possible. I would like to pull the wires out of the radar arch, then do my welding then reroute all the wires back to the orginal position. Could I possiblly split the wires with a stainless steel connection?
