First thing out of the box, let me qualify my stake in this discussion. I really thought my simplistic comment earlier put the common boat owner's needs in the proper perspective. That comment being:
TyBoo":3s94mbh2 said:
I am inclined too think that pitch is pitch, and through the water is where I want it to go
But I admit without reservation that I was out-englished by a biologist (we'll get to the science teacher in due time) when Roger reduced the concept to its purest form:
rogerbum":3s94mbh2 said:
Boat goes fast enough .....boat goes slow enough
I think the quest for perfection here is not worth the perceptible difference between it and near-perfection. As for me, I have limited resources at the moment, and finite ambition as well, so I am content to try the options at hand with the collection of props I already have, and select what seems to work the best. But that's just me this week. I certainly encourage others so inclined to refine the science.
So, now that you know I am not arguing, nor trying to disprove or dissuade, let's continue.
"Whatya know" is right! I don't dispute the math that I probably couldn't work out anyway, and I trust that the gallons per minute/prop rpm relationship is linear throughout the entire range so that at any given motor rpm the gpm calculation is the same for both models. Therefore I accept this:
It is not true that the wider rpm range means a more useful rpm range.
So, while not dismissed, the engineer is relieved of further input on this particular aspect of the discussion. Feel free to contribute to the rest of it.
Now, if I were sitting in Joe's science class having this discussion, I would raise my hand and seek some further clarification here:
This is very good, but also has its downside, in that the higher prop rpms lead to greater frictional losses, but this is relatively minor.
Wouldn't a physically larger propeller have also a larger surface area in contact with the water? And because it is doing more work in less time, create more force between the water and the surface area in order to achieve the same result? And wouldn't those factors reduce the "relatively minor" downside to an even less consequential consideration?
Furthermore, being the consummate class smart aleck, I would try to steer away from the intellectual discussion to focus on this comment:
...the sideways pot-shots at Ford, the Nerd, other outboard brands, Red Fox, and Mother Nature.
The potshots were not at all sideways. The hit to the Nerd was intended to be direct, and Ford just happens to be the best means to get to him. He likes that, you see, and responds well to it. Other outboard brands took no hit at all - I simply stated industry accepted fact. As for Greg, it was not so much a potshot as an attempt to help him open his mind a little so that he doesn't give up boating when his trusted Yamaha wears out as any piece of machinery ever made eventually will when used as intended. And just acknowledging that shows my great respect for Mother Nature.
Dan - If they do not make the prop you need, might you consider a ProPulse adjustable? At least for the sake of experimentation before putting the hammer to a piece of metal that costs more to replace. Or if not the four bladed ProPulse, maybe a conventional four blade prop? It is my simple minded understanding that a four blade on these small outboards produce a result comparable to a three blade with a 1" higher pitch.
And by the way, you're welcome!
Actually I'm glad you did
Ain't this fun?
