Prop for a CD 22 Cruiser
kevrangray
Aug 31, 2010
120
2005
C-Chief
I'm having to replace the prop on my C-Dory and was just curious if there was a more preferred prop that others have gone with instead of replacing with the exact same prop that I'm taking off. I mainly use it in fresh water but will be putting in salt water eventually.
Any thoughts or recommendations would be appreciated,
Kevin
two day and 50 views but no post... I will take a whack at it.
If you liked the prop you had and it delivered the correct rpm range at wot for your motor at the normal weight load you run your boat then you should stick with that prop and pitch. If how every you are not getting the right rpm at wot then you can go up or down in pitch to correct that.
Do a search for prop on the site and you will find a ton of info on prop pitch and the old 3 vs 4 blades as well as alum vs stainless steel.
For my money I like a SS four blade in the right pitch.
Thank you very much. I checked on one at a prop shop here locally in Redding, California and for the same set up it runs 99.00 for a used one that is in excellent shape. Just a quick question for you, when RPM is usually the best to maintain for fuel economy?
Thanks much,
Kevin
Kevin-
A 15 inch pitch 4-blade Solas prop is usually an excellent choice for a CD-22 Cruiser with a Honda 90, some variable loading, and some occasional higher altitude use, such as 3,000-6,000 feet.
The lower pitch (as compared to a 17 inch prop) plus the extra grip from the extra blade gives you better acceleration out of the hole . Also, 4 blades vibrate less at low rpm than 3 blades, like at less than 1000 rpm where you can "feel" the blades turn.
The trade -offs are that the lower pitch plus the extra drag from the extra blade limits the top end and will give you slightly less mph.
A 4 blade stainless prop will cost $500-$600 retail, whereas the aluminum equivalent $130 & up.
If you go up to a lake like Eagle Lake, at 5100+ feet, you'll also appreciate having dropped down two inches in pitch, as the boat will appear to lose less HP, acceleration and top end.
See if a dealer in the Redding area will let you try out a new prop with the provision to buy or swap it out after a trial run. Phil's Propeller may even have a used prop or two you can trial run with.
Good Luck!
Joe. :teeth :thup
Rpm to mph to mpg is a hard question because it depends on so much. but long story short my 22 with 90 got the best milage at 4200 Rpm on calm to small chop. It just depends on how you have the boat loaded and trimed.
