- Joined
- Oct 23, 2003
- Messages
- 2,869
- Reaction score
- 9
- Location
- Port Angeles
- C Dory Year
- 1995
- C Dory Model
- 25 Cruise Ship
hardee":1qa6d1mm said:Correct me if I'm wrong but don't the E-tecs burn (as in use) all of their oil.
I'm not a mechanic, nor do I own one but if it is 2 cycle, then the oil is mixed with the fuel, (albeit in the E-Tec case, the engine does the mixing), even though you don't have to mix it in the tank. So how much of that oil gets used for say 40 gallons of gas? And that oil is how much$ so we can compare peaches to apricots :wink :wink
I was bored, so did a quick search in a few places.
Seems like a common range of E-Tec oil usage is between 60:1 and 90:1. Usage seems to be highly dependent on how the engine is used, hence the wide range. Trolling = low oil usage, high RPM's = higher.
So, for the sake of argument - call it 75:1.
At roughly $45/gallon for XD-100 E-Tec oil, that adds roughly 60 cents per gallon of gas.
However...the above expense is offset by the lack of engine oil changes on the 2-stroke E-Tec. That's a whole 'nother can of worms with plenty of it's own variables (oil type, quantity, change intervals, dealer/owner doing the work etc.), so who knows which one has a lower oil expense.
My guess is, when you add it all up - oil expense shouldn't be a determining factor in whether to go with en E-Tec or not.
