Just had my trailer bearings replaced, repacked, and regreased. Trailer mechanic says that the Posi Lube grease feature is not as good the Bearing Buddies. The Posi Lube allows you to grease the bearings from a zirk fitting without removing the hubs from the axle. You can actually fully grease the bearings from the zirk. The drawback he says is that when the bearings get hot and you submerge the wheels (bearings) in water, the water is pulled into the grease.
The mechanic says that the Bearing Buddies keep pressure on the hub and do not allow water to penetrate and that they are a better system.
I bought a set of Bearing Buddies and was told just to remove the cap off the wheel and replace with the Bearing Buddy and fill with grease. Then I see on line that bearing buddies can not be used on a posi lube hub.
I called another place and they say that all I need to do is remove the zirk fitting on the posi lube and put the bearing buddy on, or if the zirk of the bearing buddy is offset from the zirk of the posi lube, then it is ok. Grease through the bearing buddy and it will bypass the posi lube zirk and still grease the bearings. But he says why replace the posi lube system better because it is better. Before I was confused. Now I am totally confused.
Any opinions or experience out there before I mess something up?
Swee Pea
Swee Pea
