Oh Boy,
Sounds like I may be heading in the same directions as cislander. I just ordered a 25 Cruiser with a 200 hp Yamaha on the back. I spent alot of time in bass boats doing 60 or 70 mph so I will need to do some adjusting. But I am excited about it. I love the way the C Dory seems so salty and seaworthy. Also, I'll have my wife along alot of the time.
So let me get this straight...
To come up onto plane have the motor and trim tabs all the way down. Gradually bring them up as you get on plane.
For smooth water cruising the motor and trim tabs should be up, with right and left tab adjustments for leveling side to side. If you go above 20 knots or so and the bow is down it will start to knife thru the water like a fin and things can get squirrelly quick. As well, around corners the stern will tend to slide because it is so flat.
(Would a four blade prop help to give the stern more bite on corners?)
For big chop and swells bring the motor and trim tabs down (all the way down?) so the bow will plow thru the swells at say 10 or 12 knots. I'm assuming that means that waves are coming over the bow fairly often. Take your time, knowing that you are safe and seaworthy.
Thanks, this post is very helpful.
joefish
joefish
