When the boat is on a full plane, the Permatrim. (You did put a Permatrim on?) should ride just on the surface of the water. If not, then move the engine up a hole to see if you can achieve this. Also the trim tab (you do have trim tabs also?) can and should be used to get the boat on a plane. 9 to 10 mph is marginal for a full plane for my current 25--once you are at 14 mph definitely on a full plane, despite a very heavy boat. (Although the 25's 100 gallon fuel tank is under the cockpit floor, the water or holding tank, (depending on year) is all of the way aft.
To get on a low speed plane, trim tabs need to be down, and the bow trimmed down with the engine also--once on the plane, then you can slowly bring up the engine--so the Permatrim is parallel to the surface of the water...
