Jay,
Thanks for your thoughts. If the Permitrim (or Whale Tale) is not running on the surface, it tends to increase drag more. The motor should be set so that the anti ventilation plate sits right on the surface when running. If the plate is running on the surface, it makes little difference as to the thickness of the metal. Not that hard to look at the engine, when on a plane on calm water. (Of course an adjustable jack plate is the best way to determine exactly where the engine belongs--but not necessary or practical in the C Dory 25. Plus jack plates set the engine back further, and make a whole other set of dynamic issues.)
The question is raised does the fin alone cause drag to the extent of loss of speed, or is it the effect that the fin has on the trim of the boat. I would argue that most is the effect of the trim is the major factor. I did a lot of playing around with fuel flow and attitude on the 25.
Definitely you need to consult with the manufacture of the tabs. I don't know if you had Lenco, Bennett, or Boat Leveler tabs (I have all 3 on my own C Dories). Generally Tabman (Bennett) will tell you how much more tab extension (that is putting on a longer plate or wider plate) will be allowed without damage to the cylinders. I personally would not add area, with out consulting the manufacture.
Generally I use the tabs to trim the boat side to side, and to an extent less to push the bow down.
I am a bit concerned by your statement about porpoising. The boats should not porpoise. The 25 is inherently a stable hull design, and the only evidence I have seen of instability, is either exceeding the 30 knot speed limit (and this is not constant), or trimming the bow down excessively--and that is more in the way of bow steering or broaching--not porpoising.
Porpoising is a very complex subject, but it implies that there is a serious imbalance on the boat, or deformity of the hull (hook of the aft planing surface is most common). You should not have to have any trim tab when running…
Several discussions of porpoising: (The first one is more what we have with the C Dorys, and that is weight distribution. The second more for high speed boats, where it is a very dangerous issue--and perhaps the dynamics are different between the two)
http://continuouswave.com/ubb/Forum4/HTML/005556.html
http://www.boatdesign.net/forums/boat-d ... -9509.html
Hard to know exactly what is going on, without ridding in the boat, or watching it from along side to see. I had the 22 with no tab or foil. My 25 came with trim tabs, and I added the Permitrim, and was able to compare the difference--which was enough to make the ride far more comfortable.
Of course a lot depends on how the boat is loaded and balanced. The current 22 has Lenco tabs, and a Doel Fin (When I first got the boat there were no Permitrims in the country for the Honda 90--so I just never got around to changing it out--and I will).
