Steady Eddy,
I had a 40 HP engine on a CD 16 Cruiser, which is more stern-heavy than an Angler, and could easily get up to speeds of 21 to 26 MPH, depending on the direction of the current. You start with setting the trim angle so that the bow is down, and then adjust trim upwards to an optimal angle as you go on plane. If you are leaping out of the water, you probably have the bow angle set too high, and are applying way too much initial power. Either that, or you have so much weight at the stern of your 16 that you are stern heavy. If that is the case, it would be helpful to move more weight toward the bow. From what people have said on this website, Permatrim should get you out of the hole quicker, and more easily keep down your bow -- particularly at slow speeds. Unfortunately, I had a Suzuki, and putting on any hydrofoil on a Suzuki invalidates the motor's warranty. Other manufacturers like Honda don't mind, and they even market their own hydrofoil.
Rich
Rich
