Permatrim
Our Permatrim on the 22 with Honda 90 puts up a lot of side spray when we drop the motor down below halfway (as per the trim gage). Is the side spray normal?
Kevin
For the Brats that need to get the bow down, try transom wedges.
Gives you 5 degrees more down trim with less drag than tabs or a permatrim.
Have used them with great success for decades on all sorts of boats.
Currently have one on my 22, as well as a permatrim, no trim tabs.
We handle the side to side trim with load placement.
Have the Honda twin forty's and for eight years have used just the bennett trim tabs with very satisfactory results, except on the Alaska cruises with our extreme weight. Then even with the trim tabs fully extended & shifting to the sleeping area much of the stuff during the day felt would improve performance, milage, & ride if the bow could be lowered, so decided to install Permatrims before going to Yellowstone this year. Won't know until next years Southeast Alaska cruise how well the combination works under extreme boat loading, but am overall pleased with them now. With full fuel & water tanks & the boat medium heavy with gear found best performance to be to have the Permatrims aligned with bottom of the transom & 40 percent on the Bennent tabs at 15 mph. Of course at higher or lower speeds the optimum percentage of trim would change, but what remained constant was performance was always best if the Permatrims remained aligned with the transom & trim made with the Bennets. When I wanted the bow down more going into the chop could really then force the bow down much better then ever before using both the Permatrims & Bennent tabs making for the smoothest ride into heavy chop we've experienced yet. The ability to have more combinations of trim & just plain more trim available is definitely a plus. They also solved the problem with prop ventilation I have had at times when trimming into chop or with moderate to heavy load. Would under these conditions in the past have to trim the motors way down along with the the trim tabs even further reducing performance efficiency to stop the ventilation.
Now the negative. The Permatrims reduced my WOT rpm just enough (from 5100 to 4900) that prop changes had to be made to run at the 8000 feet elevation of Yellowstone Lake. Ended up with new stainless 11 7/8 X 10 pitch that max out now at 5450 rpm (Honda 40 likes 5000 to 6000) at 21 mph.
Dave I cant resist . It sounds like you are heavily loaded in a life style manor as well as shifty. I would advise anyone to use trim tabs first and to analyze the need for Permatrim later . Wedges are a good addition to stern heavy boats . They will bring the bow down in a geometric or balanced manor ,have no permanent downside and retain the tabs available for you for major leveling and serious bow stuffing . Permatrims are a necessity on 16s , but from all I have absorbed from this site ,the jury is still out on most models . Once you drill those holes , you just want it to be the right thing........
Marc
Marc,
Do you have a picture of what a stern wedge looks like?
Our 22 came with twin 40's, permatrims and stern wedges. The pins that limit the down trim are in the second hole from the bottom which seems to negate the wedges. I assumed the dealer set it up that way and knew what they were doing. I wonder if the pins are relocated to the bottom hole the permatrims could be bent or damaged though I can't imagine using that much downtrim at planing speed. Quite likely I'm not getting full benefit of them due to ignorance.
Marc,
Thanks for the link. Now I understand. I am not sure of the transom wedge would be any better or worse than a Permatrim. Somebody really needs to do some detailed testing of both to see if a wedge increasing the angle of the ventilation plate in the water coupled with a propeller thrust angle that is not in line with the motion of the boat raises the stern more with less drag than a Permatrim.
My experience with a Permatrim on my 25 seems to show the best fuel flow numbers at any speed are obtained by a combination of trim tabs to push the stern up/bow down, with the motor trimmed up to be parallel to the direction of travel. The effect of the Permatrim seems to be to keep the stern a little higher. I generally run with the motor in one position only (trimmed up toward a 0 angle) unless more down trim is needed due to sea conditions. As speed increases, I back off on the trim tabs such that at 25 mph, I have about 1/3 to 1/4 tab down and at 28 mph, I have them completely retracted. At 12 mph they are full down.
I tried using using the Permatrim for more bow down with less trim tabs and consistently the trim tab adjustment resulted in the lowest fuel flow at any given speed. If I could design it, I would look at a fixed transom flap between the trim tabs with a notch for the motor as the best approach since it would offer the lowest drag.
I must confess, I don't know which way to go. I've been going back and forth on this issue; the cost, the holes, is it "worth" it? I can't judge based on fuel consumption numbers as we do not have a fuel use meter.
I usually run nearly full trim tabs down as the boat always seems "ass" heavy to me and we do not travel "heavy". IMO with the water tank in the lower bilge (2007) it only adds to the stern heavy attitude. We're in the process of adding a 9.8 kicker, so that will be ANOTHER ~100 lbs astern. Guess I'll see how it handles once that's added and go from there.
For goodness sakes, bite the bullet (sorry for the metaphor) and do it. You won't be sorry. It's the price of about 15 McDonalds meals... And you get to keep it! :wink:
Or buy and eat the 15 McDonalds meals. Let M drive the boat ,you sit up in the V berth. With the weight you gain from all that fat and empty calories you will bring the bow down!
After reading all the posts, I think I am sold on adding the Permatrim to our Honda BF75. What is the supplier everyone is using?
Shipyard Island Marine is the US distributer: 800-213-3323
And, as I recall, the ONLY US distributor. I think they are made "Down Under".. :wink:
Instead of buying the permatrim go look at( Bobs speed shop )the stabilizer plate does the same thing as the permatrim but is only $60 and is made in america We used one on our cd-22 look in our duck folder
Go look at Marc's (wefings) remarks about wedges
One thing to remember is that the permatrims should run on the surface of the water at speed, not below the surface. I have never used the "Bob's Machine Shop" fins, but they do make good products, and I am considering one of their jack plates for the Caracal.
Thanks again. I'll look into the American made stabilizer plate.
I think I might need a Permatrim for my 16 Angler. Even on virtually flat water I find that I really can't run faster than appx. 16-17 mph. or the boat starts to porpoise. With hard acceleration and the new engine (Honda 50 EFI) the boat almost seems to leap out of the water, then bangs hard on re-entering the water. I somehow need to get the bow down and the boat running more level. Does anyone here have experience with Permatrims on a CD 16? Any input and/or suggestions would be greatly appreciated. Thanks, Mike.
You might want to consider trim tabs on the 16. Also check the balance of the load. A boat which porpoises is often out of balance, or there is a hook in the bottom etc. That type of handling can be dangerous--and is not at all normal.
