chas231
- Joined
- Feb 22, 2009
- Messages
- 26
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDO22032C202
- Vessel Name
- Betsy's Dunkard
Greetings. My 2002 CD22 is powered by a Yamaha 100. While cruising, the voltmeter is flashing and reading 16.6 volts, so I assume the system is overcharging? I suspect that it's been charging this way for a while. I have two deep cycle batteries which seem to work fine, but they are five years old. The resting voltage while the motor isn't running is 12.8; at idle the voltage is 14.8. All the connections appear clean and secure. Would weak batteries cause the overcharging, or should I suspect an issue with the rectifier? Will the overcharging damage electronics? I have found all the answers to my questions inn the archives, but couldn't find anything on overcharging.
Thanks!
Chuck
Thanks!
Chuck
