One trim tab not working
ladolcevita
Sep 4, 2008
10
2007
25 Cruiser
My port side trim tab is not moving. The other seems to be working fine. I was a little low on fluid but not too much. Toped off the fluid but still not working right.
Do I maybe have some air in the line if so how do I bleed it.
Any comments would be appreciated. She's up on blocks now I'm just getting my to do list together for the new season
Thanks
Steve.
Steve, assuming you have Bennett trim tabs go to www.thehulltruth.com, there you will find a forum sponsored by Bennett with either the solution to your problem or you can post your issue on the forum and a Bennett representive will guide you through diagnosis and repair.
Eric
If you hear the pump run when you try trimming it could be the fluid needs bleeding. If you can't hear the pump run on the one side, then look and see if a wire came loose on the controls. Ron
Or corrosion in the wiring connections.
Thanks guys. I can always count on the C brats for help.
Thanks for what, did you figure out the problem? If your tabs fail on a 07 boat it would be nice to know what the problem was. Let us know when you figure it out chap.
