siddfynch
- Joined
- Jul 14, 2008
- Messages
- 39
- Reaction score
- 0
- C Dory Year
- 1983
- C Dory Model
- 22 Classic
- Vessel Name
- XerxSeas
Hi all,
I finally took the plunge last week, after 2 yrs of shopping around and tuning my interests down from an 18' aluminum skiff to a 22' C-Dory with pilot house and cuddy cabin. Got skunked on a couple local C-Dory purchases - being a rookie, I got beaten to the punch by savvy vets who pounced on good deals while I was still doing things like coming to this site to research bottom paint. I registered on this site a few weeks ago, but this is my first post.
Anyway, I jumped on a boat that was for sale remotely, trusting the seller and a remote appraiser to fill me in by phone, then drop it off at my house while I was out of town. It's a mixed bag - I probably overpaid, and the boat is not quite as turnkey as promised, but I'm glad I have it, and can now turn my attention to getting her fixed up.
First, I want to say how helpful this site has been in my search. There's a lot of advice on fixing that is obviously helpful. Maybe a little less obvious is that all the posts on trips taken, photos of boat layouts, and other such things have ben very helpful for seeing the POSSIBILITIES of the different makes and models. So thanks for sharing the successes as well as the advice. Although it's my first boat, I have run 14 to 26 footers around Alaska as part of my work, so have some exposure to them - not as much as a hands-on owner, but more than someone straight out of the armchair. My intent for this new boat is overnight trips in PWS, Seward, Homer, etc.
With that, I have a few questions that I cannot find the answer to.
First, my boat: it's a 22' Classic, 1983, with a 2006 Evinrude E-Tec engine. Uglier than the pics you guys have on this site, so I am loathe to post them.
Question #1: What is the wood laminate on the inside and outside back of the pilot house on this model? I'm talking about the console, drop-down table, and shelf behind the driver. Is this material a teak veneer, or something else? I'm trying to figure out whether to stain or sand it.
Question #2: I need to replace a 15' strand of 12/2 wiring and a 15' strand of 12/1 wiring. I figure I'll drop down in size (10/2 and 10/1), but the cost has surprised me. At least $50 just for the 10/2. Can I simply replace the 10/2 with 2 strands of the much cheaper 10/1? If so, I can buy a spool of 10/1, and my cost per foot goes way down. Or is there a safety concern in making this switch?
Question #3: The Lowrance 2800M turns out to NOT come with the chartplotter option. Does anyone have any experience with this "Navionics" card that goes into it? Is the coverage worth the $200 from West Marine, especially for Alaska waters? My only experience is with the Garmin setup, which uses a different system (and which was good enough for me).
Question #4: The electrical panel is quite the rat's nest of wires, with one bus bar, two fuse panels, and the steering cable. Has anyone on here retrofitted a cover for this whole shebang to try to keep it out of the way of toddlers and sleep-kickers in the v-berth?
Question #5: This one is really puzzling me. I have dual batteries wired to a 1--Off-2-Both Blue Seas switch. Battery 1's negative is wired in series to Battery 2. The positive cables from Battery 1 and Battery 2 go directly to the 1 and 2 terminal on the Switch. The remaining Switch terminal is wired to the motor. Now, there is also a separate wire running from Battery 2 to each of my two fuse panels. The result is that all of my electrical components in the boat can be turned on regardless of the position of the battery switch (1, 2, off, both - it all works the same).
Is this incorrect? From reading this past week, it seems like the point of a switch is usually to isolate the electronics from the starting system. Is there a benefit to my boat being wired the way it is? Regardless, what's the simplest way to achieve system separation under my setup - should I be running my positives from the fuse panels straight to a terminal on the Blue Seas switch (instead of the battery)? If so, where do my negative cables from the bus attach (still to Battery 2)?
A lot of questions here, I realize. If anyone can take a stab at any of these numbers, I'd sure appreciate it. I'd like to get her out on the water as soon as this weekend, if possible.
El Sidd
El Sidd
