potter water
- Joined
- Apr 12, 2011
- Messages
- 1,076
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- R-21 Tug
- Vessel Name
- Poopsy
Still Crazy, 22 ft cruiser, 2007.
The manual for this boat is EXTREMELY basic in regards wiring.
There are two batteries, one in each stern well, port and starboard, that are dedicated to each of the twin engines. There are 4 separate battery switches in the starboard compartment along with some other electrical whiz bangs.
All four are red, on off swivel switches and are labeled:
A. Port engine
B. Starboard engine
C. House battery(s).
D. Emergency all batteries
On the port side stern compartment is the battery for the port engine, and one house battery.
A second house battery is on the floor of the stern well next to the bilge pump.
As I run each engine, it is clear that they will each charge their dedicated battery as checked with a volt meter.
It appears that the house battery in the port compartment is charged by one of the engines. I'm not sure that the second house battery by the bilge pump is charged by either engine.
All this leaves the question about what is the proper wiring hardware to allow either engine to be charging two dissimilar batteries, one a starting battery, and the other a house battery. A no no I believe. Is there some hardware in there normally that isolates the house battery through a big ol' diode to keep it from providing current back to the engine that is charging it and makes it okay for the engine to charge two dissimilar batteries at the same time?
These are probably stupid questions, and some more poking around and measuring battery voltages may help answer my own question. But, any thoughts out there on what is proper in terms of running twin engines, and starting and house batteries would be well appreciated. I'll check the forum archives and do some looking on RV sites, but I don't know of any RV's that would have twin engines.
I think what I'd like is to have either engine or both be charging the house batteries when one or the other or both are running, as well as be charging their own dedicated starting batteries.
Also, any part numbers or sources for my dilapidated wiring boot that is in the splash well starboard wall?
A. Port engine
B. Starboard engine
