patrick and linda
- Joined
- Mar 28, 2006
- Messages
- 953
- Reaction score
- 0
- C Dory Year
- 1986
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- TOFOLLOW
- Vessel Name
- "Fan-A-Sea"
so, my trailer was built to hold a 27' to 29' boat. my boat is 28' loa, however when my boat is on the trailer at least 2 feet stick out beyond the hull. my trim tabs had ripped the carpet because the beams where longer than necessary. so, i removed the 2 beams, which were 3" width, 10" high on one side and 8 3/4" on the other, and approx. 12' long. the beams are higher on one side than the other to accommodate the hull shape. once i had the beams off i removed the poorly installed and very ripped carpet and then cut 2' off each beam. this gives me a much better fit for my boat.
i called our local sea ray dealership to purchase the replacement carpet. i needed approx. 24" wide by 13' long, they only had 12" wide and wanted $2.00 per foot. i could have used the 12" stock, but i wanted to wrap the entire beam, not just a small segment. i asked the service rep where i might get the same carpet but much wider than they had. he said they buy it from lowes and then cut it to 12" widths. bingo! i went to lowes and for $67.00 purchase the very same carpet, 13' long x 6' wide. they even cut it to 24" widths for me. what a deal!
now, the beams where higher on one side than the other and the high side had a sharp edge which helped cut the carpet when the hull applied pressure during loading. so, i sanded the edge down so that this cutting wouldn't happen again, then installed the newly purchased carpet. final product looks great and should hold up well. i used 1/2" wide x 3/4" long staples using a pneumatic senco stapler. i have 2 pictures in my album of the beams. so hope this might help anyone wanting to replace their trailer carpet.
best regards
pat
best regards
pat
