beermanPDX
I'm looking for what I would call a "75 degree stainless stanchion base for 1" tubing". They might also be called a rail base fitting. Similar to these, but a different angle:
Most of the ones I can find are at 30, 45, 60, and 90 degrees. I need something that is at 75 degrees (15 degrees off a normal right-angled fitting).
This base will be mounted in my splashwell which is fairly close to 15 degrees off of level. It will be used to capture some thick walled stainless tubing used to support one corner of a generator / seating platform.
If I can't source this part, my alternative is to cast an epoxy base (wedge) so that I can use a normal 90 degree base. This will work fine, but in addition to the extra work, the bolts will pass through the splashwell at an angle making snugging it up to a backer plate more difficult.
The hinged bimini type fittings would work since they could adapt to any angle, but they aren't necessarily made for strength in compression. This needs to take the weight of someone sitting on the platform it supports.
If anyone knows of where to find this 75 degree base or some other terminology to use in a search, I'd greatly appreciate it.
