seagrits@aol.com
Opinions?
As mentioned in a previous post, I have pretty much committed to a 2004 22 ft cruiser. Heading up to get the seatrial done next week with final survey. This is an Interesting and almost virgin boat. I have never seen a 16 year old vessel with out a little gel coat spidering, this one has none. Everything seems to be in bristol fashion and the dealership has gone through the twin 50 Honda's. Fresh water pump impellers, carbs gone through etc. Fuel tanks thoroughly cleaned as well as the water tank.
What has intrigued me further is the way these engines are mounted. There are no trim tabs, however the engines are mounted with a wedge shaped aluminum plate which is thicker the top than the bottom, allowing the trim to be closer to the hull at full down. Have any of you seen this before? If so, how well does it work over tabs in keeping the nose down.
Secondly, the wallace stove fired up with out a hitch, but was advised to run k-1 kerosene instead of diesel. Thoughts?
There's probably going to be a few more questions between now and next Thursday, so thanks in advance.
