Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,821
- Reaction score
- 181
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
You are correct in your description of Porpoising. Most boats are designed to run fairly level when on a plane, and do not need much in the way of fore and aft trim (by tabs or a engine fin). If the Permatrim is running at the surface of the water, the bow will be forced down, but there will not be much upward force on the bow (actually the effect is all at the stern--lifting or depressing the stern--opposite to the way the bow reacts).
Normally you can bring a boat on a plane faster or planing at a lower speed by giving it full tabs and permitrim engine trim all of the way down. After the boat comes on a plane, then you bring the trim up, until you get the best speed for the RPM--often backing off on the throttle. Many boats need no trim alteration. The trim tabs are used for lateral (side to side trim) and the Permatrim more for bow down. Normally you do not want to run bow down because it will cause steering problems. In your case, you put bow down too much.
There are two things which can cause erratic rapid rolling. One is "chine walking" that is where a fast boat begins to plane on one side or the other and on on its bottom. Most often will occur in V hulled boats, such as bass boats at high speed.
The other is "Bow steering" That is where the bow begins to act as a front rudder, and pushes the boat one way, and then the other. It can occure with a slow boat coming off a wave, and is a component of a slow speed broach. It can also happen with a high speed boat which puts the bow down too much. The water on one side of the bow, causes pressure to push the boat one way, and then the other, instead of going straight. The cure is to bring the bow up and slow the boat down. In your case, you were probably going at the controlable limit of the boat for its weight distribution and attitude with bow trimmed down. Further trimming of the bow down, caused the bow steer.
When running down waves, always have the trim tabs up, and you want to run with motor (Permatrim) up also.
