matt_unique
- Joined
- Feb 27, 2007
- Messages
- 1,881
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Vessel Name
- Napoleon
I will paste a thread I posted last year during winter layup:
>>Not precisely related but when I was removing my batteries this year I found an empty fuse holder right near my house battery. Everything works including both macerators and I was wondering what it could have been for. Makes sense that it may be a fuse for a Wallas even though I never had one installed in my Tomcat.<<
This is an old thread but as I'm doing spring recommission I took another look at the wires/fuses I mentioned above.
The wires run directly off the positive terminal on my starboard and port start batteries. Both have a fuse holder but no fuse. The wires disappear into a large sheath with a lot of other wires.
I wondered over the course of last season whether my bilge pump auto switches worked. The Tomcat gets only a little water in the sponsons even after days of pouring rain. Each day I arrive I always check the bilge and throw the manual switch on to drain whatever water may be there. There were some mornings when I seemed to have a decent amount pouring out when I hit the manual switch.....I wonder if these wires/fuses are for my auto switches on the bilge pumps? It would make sense because each would need a constant hot wire and each would need a fuse. Based on this assumption, what size fuse (amps) should I use?
With the enclosed Rule pumps there is no easy way to test other than to pour water in there. Any other suggestions?
