Capital Sea
Capital Sea is outfitted with 2007 Honda 90 , two batteries , on board marine charger, also Honda 9.9 (not effected)
Issue: no power to helm, no tilt at helm, battery gauge at helm shows crank battery as dead though battery is fully charged, tilt switch on 90 also has no power.
Batteries are fully charged, crank battery is new.
Thermal circuit breaker has been replaced as had corrosion.
Battery 1,2 or 1&2 switch and managment modual inspected and clean tight w/ o corrosion.
All connections have been cleaned and inspected.
Fuses in the Honda have been inspected visually and with meter.
Controls at helm confirmed as in neutral.
Fuses at battery checked.
Ground at lazeret verified.
Power verified at silinoid
Ground to block verified
Help,please.
Help,please.
