Mounting Downriggers
Crazy Ivan
Nov 11, 2012
2
HEllo.....
Just brought home my 9new to me) 2005 19 ft Angler...... Can anyone give advise on mounting downriggers. I apears that i cant get under the gunnels to bolt the mounts down.
Thanks in adavnce
Crazy Ivan
Ivan,
If the 2005 CD 19 is anything like the 2005 CD 22, you should be able to get to the bottom of the gunnel. Here's how I mounted my Cannons.
I did have flush mount rod holders that I covered with the mahogany, through bolted on the gunnel.
The later model 19 anglers have a panel on the side of the gunnel and foam behind it. If you want to mount the down riggers forward of the lazarettes, you need to cut a hole in the panel dig out some foam so you can reach under to hold the bolts and back plates and then cover the holes with a round deck plate (or similar). I believe that's what Checkpoint did on his boat. Otherwise you can mount them on the far aft corners, aft of the lazarettes. That's where I put them on my previous 22.
Mounted ours aft of the laz like previously mentioned. No problems here. I put a plywood backer board in the laz.
Rick
Dont be afraid to mount them a bit forward. When standing in the cock pit I kinda like to reach the ball and cable without leaning way overboard. Its a ergonomic thang. :wink:
Cheers!
Chris Bulovsky
22's have a couple different options, but in my not-so-humble opinion - there's only one way to mount downriggers on 16's and 19's.
Looky here.
Rick, to the left of your fishbag, it looks like you have a manual bilge pump. What model? I've been talking about doing this for a couple of years. Looks like the exhaust goes out the side, where did you put the pickup (at the bilge drain?)?
Bill, that is a great solution!
The pump says Bosworth on the handle. It was already installed when we bought the boat. The intake is in the bilge pump depression at the transom. Sure works great.
Thanks!
Outstanding Suggestions..... Mounted the Two rear Riggers yesterday, and have ordered the supplies for the side rigger mounts
Todd
