Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 13
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Hi all,
I'm wondering if anyone has found a good exterior marine paint color match for the C-Dory "white" of the outside of the boat (I checked the archives and found info on a good match for the interior cabinetry, so that's filed away for reference :thup).
I'll explain why, because otherwise I would expect people to recommend I use gelcoat. Actually, I have purchased some gelcoat by using the code numbers I found here, and it's a perfect match, so that's sweet. In this case, I have something I would just prefer to paint. I'm installing a Mini-Jacker for the second engine, and it comes with a built up plywood pad for the inside. I've coated the whole thing in neat epoxy (lots of end grain!), but now would like to paint it - slightly for looks, but mostly because epoxy and UV do not play well together. Sure, it doesn't need to match exactly, but before I go ahead and order some EasyPoxy, Brightsides, or similar (they have a number of whites that look like they might work), I figured I'd see if anyone had determined which one was the best color match. Once I have a can, I may use it for some other (non-gelcoat) projects I have in mind, such as a splashwell table - so a nice match would be preferable to just any-old white.
I'm way out in the sticks at the moment, so would prefer to find a color I can just order (the UPS truck does come out this far
), since I will be mounting the Mini-Jacker soon (before I would get to a town with a big paint store). It will be a lot easier to paint that plywood pad before I mount it.
Sunbeam :hot
Sunbeam :hot
