I follow the oil change standards of 100 hours or one year. However there are other factors. An engine which is "making oil" really has fuel getting into the crankcase and mixing with the oil. That does cause decreased viscosity and can increase wear. In the outboard which are run at low speed, this makes little difference. For high speed that is a different story, since the oil temperature, and wear is accelerated.
Although I have not done extended oil changes with an outboard. There is a case where it can be justified. For example going on the loop, running at displacement speeds all of the time. I would feel confident changing every 200 hours. Especially if running synthetic oil. In diesel engines I extended the 200 hour change interval to 300 or 400 hours on long passages where the engine was run at a constant 1500 RPM. In that case you are actually considering fuel use rather than time. On a passage you are running 24 hours in a day--if you stuck to the 100 hour--you would changing oil every 4 days.
The Sacramento Delta had (not sure if they are in operation now) short run car ferry boats which had a GM 6-71 which ran 24 hours a day at a constant 1200 RPM. The engines were never shut down. Oil was added by loss/or time if there was no loss--with a gallon removed and a fresh gallon added. (GM 6-71 diesels tend to "use oil" . The oil capacity is 8 gallons and a very efficient filtering system was used to remove contaminates. At the end of 2 years, the engines were shut down and had a full overhaul. 2 years x 24 hours, is 17280 hours. There was never a failure of these engines.
