Alyssa Jean
(Pat on Daydream with the composting toilet need not respond)
I am contemplating the replacement of the factory Jabsco Marine Toilet with either a vacuflush or Sealand 8818 electric. Saw both today at the Trawlerfest. The vacufluch only uses about a pint of fresh water to flush. It also has the largest unit to mount somewhere to make the system work. The electric's workings outside the toilet are much smaller. Both would flush to the existing waste tank. The power on the electric as I remember it is in the neighborhood of 6 amps. But this is a quick momentary discharge of the batteries. The fact that it uses fresh water eliminates most of the marine smell you get from using sea water. And that is where I do 99% of my boating.
Any thoughts or experience with the electric?
