Length tow vehicle and boat/trailer
Of course--another vote for the 22 over the 25--but in my case, I have to keep my Admiral happy, and the back pain getting in and out of the bunk is a major factor. Over all the upgrade is worth the hassel.
We were told about the Host Motor coach 270 on another forum. This is a 27 foot class C, with a quad cab, and built on a 2 x 4 or 4 x 5 550 Ford Chassis. A pretty nice rig--with two slides, and a cab over bed--and a possiable "hard side tent" queen in the back. It is a bit pricey at the over $150K range! But some units have a towing capacity of about 12,600 lbs. http://www.hostcampers.com/subs/motorco ... h_270.html
I also started playing with the numbers on the current RV--the same drive train, axels etc are used on up to 37 footers in the same Holiday Rambler Series. My current rig has a carrying capacity of 3000 lbs, and gross combined weigth rating of 8,000 lbs. The hitch is the major limiting issue, and I am considering going to one of the good local hitch shops and seeing what frame re-enforcements we might consider. We have been regularly towing 4500 to 5000 lbs--and going another 2000 lbs may not really have that much of an effect, except minor shortening of the longivity of the engine and tranny... However another real question might be if any handling characteritics were changed. Perhaps an Equalizer hitch would prevent those issues--plus allow a larger capacity with the current hitch, just -re-enforced....
Thanks for the comments.
My 32' motorhome is rated to tow 5000#, just enough for the 22 & trailer (4200#). This setup measures 61 ft. with the outboards up. The nice lady at the WA State Ferries told me to let the motors down for the measurement and I would be under 60 ft and save $10. Nice gal.
All this works so well it is hard to imagine buying a heavy 25 to gain a complicated head.
Here is CA, they like you to stay within the 65' combined length max. However, I have a bud with a 42' Newell towing a "stacker" enclosed race car trailer that measures 80 ft. ! He has not been stopped...yet.
Another bud tows a..<gulp> 33 ft. powerboat! Notice I didn't say trailer-boat. He camps in the boat and tows with a diesel PU, so he is OK on length but.......the boat has a 9 1/2 ft beam !!!!!! It LOOKS really big behind the PU. His secret: This is a permit load in all states, no question...but the permit process is an expensive pain. So, he just puts a "Wide Load" sign on...front and rear, and off he goes. No permit, no nada. His explanation is that the authorities are reluctant to stop a load like that, clearly too wide but otherwise not causing any great problems, because they have to declare your trip terminated and sit right there and babysit you until the machinery of justice slowly grinds to correct things. He has been doing this for years all over the country.
Have fun out there...
Roy
I heard of another 42' motor home towing a Stacker with a Ford Explorer on the bottom and the 20 foot Proline on top, plus a full golf cart on the front--again over 70 feet--never stopped in over 50,000 miles.
I also was put onto a web site: http://ops.fhwa.dot.gov/freight/publica ... htm#length
This is from the Federal Highway Association, and confirms that commercial boat carriers are allowed soft bumpers in front (which gives us another 6") plus an overhang of 4 feet on the rear past the rear of the trailer for boat transport. Since the recreational vehicles follow the commercial regs, there are those who believe that the 4 foot overhang holds for boats also--and if so that would solve our "problem"...
The change was more than for a complicated head...There are a number of other pluses in the CD 25 (but the weight and length is a price you pay).
