iconoclastastic
chucko":sb68v3a5 said:So far I have found a plug n play replacement for every bulb on the boat,I recommend superbrightleds.com and the marine beams for the colored nav lights :smiled
Hi,
you have only found a replacement for every bulb on your boat because who ever designed your fixtures left clearance for the idiots who design LEDs and call them exact replacements but decide to add .040 inches to the length!
If anyone could find me an LED replacement that is the SAME length as a GE90 incandescent bulb I would be so thankful
superbrightled is a a joke i have a nice LED exact replacement. It is siting on a shelf in my room because it is too long to fit in my boat. It seems to me that if interference is going to be an issue and you are going to be sloppy or just ignore dimensions on your EXACT replacement (item) it really should be slightly undersized not oversized
Could i get new fixtures, drill holes, gel coat, or get fancy with soldering irons and individual LEDs and cracking of bases - you bet.
I really would rather not be doing this.. am I asking too much?
